Дата: Понедельник, 03.Сен.2018, 18:28 | Сообщение # 2
У вас сообщений: 40
Error No. 425 of AP ID 32 Meaning: Basic unit: No communication with master drive 1 (U80 "Column").
Meaning: Basic unit: communication or SW error between master drive (MD) U80 column or U90 spotfilm device and XCU (SCU)
Reason, Cause: If errors 637-32, 638-32, 425-32 and 426-32 occur together, the CAN communication to the XCU (D100) is interrupted.
Action: Check the CAN connection using the Wiring Diagram. It is possible that a terminal resistor is missing or that one terminal resistor too many has been activated! Check the U80 column and U90 spotfilm device master drive (MD) power supplies. CAN Master drive defective.
007 34 ICONOS table side control or control console not ready
Error No. 423 of AP ID 34 Meaning: Basic unit: Timeout during bootup of remote control console 1. No communication between SCU-remote control console 1.
Reason, Cause: Timeout error, response from remote control console 1 to the XCU took too long.
Action: - Check the + 24 V power supply for control console 1. - Check the position of the DIP switches (programmable for remote control console 1 or 2) on the remote control console. - Is the remote control console plugged into the correct X302 connector on the D1 BUC board? - CAN bus to control console 1 open. Check the CAN connection against the Wiring Diagram. - CAN control console 1 defective, replace control console.
Error No. 543 of AP ID 32 Meaning: Basic unit: BUC monitoring responded, "Still alive" signal to the SCU missing.
Reason, Cause: Not relevant for service.
This error is anticipated only in the software test. The cause is from another error that has a time relationship to this error.
На примере моего аппарата , переломился провод, на сгибе от подошвы , до колонны и решетки . там очень маленький радиус заложен с завода ... (информационные, у меня синего цвета) Удачи !
спасибо всем за отклик, проблема возникает при работе хаотично, к сожалению даже не могу сказать когда возникает (сегодня весь день гонял и нор), завтра буду весь день на душой лаборанта сидеть. Думаю что причина в контроле двигателя колоны или где то кабель. fred1 спасибо за информацию, будем проверять)
