Немагнитный тулкит для МРТ
dimakratДата: Четверг, 15.Сен.2011, 19:25 | Сообщение # 1
Ростов-Волгоград
Уважаемые форумчане, подскажите пожалуйста примерный перечень немагнитного инструмента необходимого для обслужива МРТ Siemens Magnetom Symphony 1,5Тл и где его лучше заказать?
KAMEROved_2Дата: Пятница, 30.Дек.2011, 22:57 | Сообщение # 2
Старший Помощник KAMEROved
SPb
Non-magnetic steel tool set
complete
Non-magnetic fork wrench 6/7mm
Non-magnetic fork wrench 8/9 mm
Non-magnetic fork wrench 10/11 mm
Non-magnetic fork wrench 12/13 mm
Non-magnetic fork wrench 14/15 mm
Non-magnetic fork wrench 16/17 mm
Non-magnetic fork wrench 18/19 mm
Non-magnetic fork wrench 20/22 mm
Non-magnetic fork wrench 21/23mm
Non-magnetic fork wrench 24/26mm
Double open ended wrench 27X32
Double open ended wrench 30X36
Cranked wrench key (imbus) 2.5mm
Allen key 3mm with ball head no
Allen key 4mm with ball head no
Allen key 5mm with ball head no
Allen key 6mm with ball head no
Allen key 8mm with ball head no
Non-magnetic Allen key 2mm
Non-magnetic Allen key 3mm
Non-magnetic Allen key 4mm
Non-magnetic Allen key 5mm
Non-magnetic Allen key 6mm
Non-magnetic Allen key 8mm
Non-magnetic Allen key 10mm
' on-magnet'c or wrenc lU/ll
Non-magnetic Allen key 1/16
Non-magnetic Allen key 3/32
Screwdriver 0.6x4 short, nonmag.
Screwdriver 1x6.5 short, nonmag.
Screwdriver 1.2x8 nonmag
Non-magnetic screwdriver 0.6x2
Non-magnetic screwdriver 0.8x3
Non-magnetic screwdriver 1.0x4
Non-magnetic screwdriver 1.6
Non-mag. Phillips screwdriver 3mm
Non-mag. Phillips screwdr. 4.5mm
Non-mag. Phillips screwdr. 6mm
Non-magnetic steel tweezers 110mm
Non-magnetic steel diagonal cutter
Non-magnetic steel flat round plier
Non-magnetic steel water pump plier
Torx key, TX9 nonmagnetic
Torx key, TX10 nonmagnetic
Torx key, TX15 nonmagnetic
Torx key, TX20 nonmagnetic
Torx key, TX25 nonmagnetic
Torx key, TX27 nonmagnetic
Torx key, TX30 non-mag
Torx key, TX40 non-mag
rathomeДата: Вторник, 03.Янв.2012, 00:07 | Сообщение # 3
У вас сообщений: 51
Мединженер
Винница
Заказывать лучше у газовиков и нефтяников он используют медно-бериллиевый инструмент который не искрит,
он же диамагнитный, стоит намного дешевле, чем оригинальный томографический, но тоже не мало.
найти его можно просто в Гугле.
Saimon47saДата: Понедельник, 06.Фев.2012, 20:46 | Сообщение # 4
У вас сообщений: 21
инструмент такой можно и наш найти буквально сегодня народ обсуждал его, к сожалению, я услышал что его производит какой-то инстр. завод в красноярской области.поищите в инете может попадется
Homo_SapiensДата: Понедельник, 27.Фев.2012, 02:50 | Сообщение # 5
У вас сообщений: 32
Одесса
dimakrat, на самое первое время, если нужно что-то крутить в магните отвертку шлицевую можно сделать из вилки :)
Пищевая нержавейка немагнитна.
А KAMEROved_2 список тебе дал классный :)
Как показала практика, у меня на 0,5 Тл магните нужной штукой является газовый ключ (под гайку стрингера - переливки), ключ на 24, помоему - под крышки токовводов, шлицевые отвертки 3 мм и 4 мм, ну и можно шестигранник на 4 мм, но необязательно.
А вообще закономерность: чем больше ферромагнитный предмет - тем сильнее его притягивает - тем труднее ним работать :)
Сообщение отредактировал Homo_Sapiens - Понедельник, 27.Фев.2012, 02:54
KVIДата: Вторник, 20.Мар.2012, 00:27 | Сообщение # 6
У вас сообщений: 396
МРТ
Елец
Медно-бериллиевый инструмент - дрянь. Вещь одноразовая. Особенно крестовые отвертки и мелкие шестигранники. Очень не прочные.
Нужен либо титан, либо подходящая нержавейка. Мы набор ключей и отверток заказывали у америкосов. Но всё это очень не дёшево. Да и проблемы с доставкой и таможней. (удалось провезти через таможнню вместе с очередным томографом). Контакты американцев сразу не скажу - уже год прошел с тех пор,искать надо)
sledgeДата: Вторник, 20.Мар.2012, 03:51 | Сообщение # 7
У вас сообщений: 192
www.imprex.net к примеру
KVIДата: Вторник, 20.Мар.2012, 19:20 | Сообщение # 8
МРТ
Елец
sledge, Да. Это они.
FedorMДата: Суббота, 01.Сен.2012, 20:58 | Сообщение # 9
У вас сообщений: 271
сервисный инженер МРТ
В принципе, почти все делается под заказ из нержавейки. Ключи лазерной резкой из толстого листа, шестигранники фрезеруются на концах из прутка, отвертки тоже. Но в малых объемах дорого.
Из российских ключей - смотрите наборы ключей и молотки из сплава ВБ-3. Мягковат, но и стоит гуманно.
Недавно вот купил у китайцев прямо с завода 3 набора бериллиевой бронзы за 900 баксов с доставкой. Бериллиевая бронза не сильно прочный материал, но и применять мы их планируем только там, где обычный инструмент уже совсем не годится. Например, для вынимания боди-катушки под полем.
Состав каждого - пассатижи-тонконосы, малые бокорезы (для стяжек), метрические шестигранники, разводник до 35, рожковый 10х13 и еще что-то.
Для Сименса 1,5Т такого набора хватает.
Как приедет - скажу насчет качества.
UPD Приехал. Упаковано мощно, в алюминиевый чемодан и две коробки. Кусачки стяжки кусают. Шестигранники с нескольких оборотов не слизываются. Практика покажет, что там с качеством, но чтоб я еще раз покупал, "как положено", если можно напрямую ...
Сообщение отредактировал FedorM - Среда, 05.Сен.2012, 23:01
remMRTДата: Понедельник, 17.Мар.2014, 10:13 | Сообщение # 10
Что касается ремонтов МРТ, я использую титановый инструмент газовый под гайку стрингера - переливки, так же есть титановые шестигранники, отвертки и плоскогубцы, набор сами скомплектовали какой нужен, нам в кейсе все поставили атэкс-инструмент [http://atex-tools.ru/catalog/list/17]My WebPage[/], стоит не так дорого, тем более есть инструмент не терять, то он - вечный.
Сообщение отредактировал remMRT - Понедельник, 17.Мар.2014, 10:17
Denia777Дата: Пятница, 05.Апр.2019, 18:21 | Сообщение # 11
Продам новый набор титановых инструментов imprex. https://www.imprex.net/product/siemens-titanium-hand-tool-kit-non-magnetic-3t-mr-conditional/ цена по договорённости. По всем вопросам в личку или по телефону 89265393250
Сообщение отредактировал Denia777 - Пятница, 05.Апр.2019, 19:43
vican75Дата: Среда, 16.Фев.2022, 08:07 | Сообщение # 12
У вас сообщений: 31
Нижегородская обл.
Всем привет!
Предложили немагнитный инструмент для МРТ из AISI 304 (аналог по ГОСТ 08Х18Н10, читаем как 0,08 %С 18Cr 10 %Ni) - высоколегированная хромоникелевая нержавеющая сталь.
Кто-нибудь работал с этим инструментом?
И как он себя видёт при 1,5 тесла?
1. andrey162007[21.Дек.2024]
2. amgadm[20.Дек.2024]
3. Lerena[20.Дек.2024]
4. maxxv[20.Дек.2024]
5. shabalov10[20.Дек.2024]
7. Alihanov[20.Дек.2024]
8. dimfo[20.Дек.2024]
9. Vitalii[19.Дек.2024]
10. IDM[19.Дек.2024]
