siemens r200
kloun71Дата: Понедельник, 16.Фев.2015, 09:27 | Сообщение # 1
Автор темы
У вас сообщений: 273
тула
Возникла ошибка 555/035 при запуске аппарата, стол блокирован, помогите кто чем может.
anton26Дата: Понедельник, 16.Фев.2015, 11:28 | Сообщение # 2
У вас сообщений: 375
Error No. 555 of AP ID 32
Meaning:
Basic unit: Unit was at one of the safety limit switches during operation. Emergency stop not pressed. Movements blocked.
Reason, Cause:
- Safety switch strips S80, S90 at foot end or S81, S91 at head end on support strut for table frame (collision protection between spotfilm device - table strut) actuated?
- I.I. contact safety device safety switch S301 actuated?
- Spotfilm device safety switch strip (collision protection on patient arm with tomo rod) actuated?
- External safety circuit (ceiling photo-sensitive cell, door contact, step plate) open, X54 BUC jumper open?
- A unit movement is at the safety limit switch (S150 tilt drive, S140 table lift, S160 and S161 table longitudinal).
- Temperature on transformer too high > 105°? Check using SSW/ Monitoring/ Monitoring Status: M1 T1 thermal switch.
- SW-controlled BUC safety relays, K6, K7, deenergized? Reason: A movement took place without control or the potentiometer is defective. Watch for subsequent errors!
- Chain break monitor for table lift responded, a microswitch, S6 - S9, actuated.
- Temperature for table longitudinal drive too high? Switch S169 responded.
Action:
- Correct cause for possible collision.
- Check the mechanical position of the movement to the electrically sensed position (potentiometer). SSW Diagnostic/ Tests/ Monitoring/ Monitoring: Unit position.
- Using the SSW/ Diagnostic/ Tests/ Movement tests with Service buttons, move the drive out of the safety circuit. New potentiometer adjustment, possibly replace potentiometer (see the potentiometer Help text).
kloun71Дата: Понедельник, 16.Фев.2015, 15:11 | Сообщение # 3
Автор темы
тула
спасибо огромное
1. Электрон КРТ стол SUP...[Benq (14.Авг.2025)]
2. ремонт спектрофотоме...[vasyalee (13.Авг.2025)]
3. УЗИ Philips HD3 EXP[VG54 (13.Авг.2025)]
4. Размораживатель плазм...[yblod5 (13.Авг.2025)]
5. Диаметры трубок для а...[ALROS (12.Авг.2025)]
6. Термостат ТС-80М-2[yblod5 (09.Авг.2025)]
7. Радиовизиограф Woson[seabee (09.Авг.2025)]
8. Скалер Piezotome Solo...[seabee (09.Авг.2025)]
9. Стерилизатор паровой ...[fiksa555 (07.Авг.2025)]
1. Philips HD3-EXP[13.Авг.2025]
2. Рентгеновское оборудо...[08.Авг.2025]
3. VersaMed iVent201 Сер...[13.Фев.2025]
4. Гелпик КРД Ренекс РЦ ...[09.Фев.2025]
5. Офтальмологическая ус...[31.Окт.2024]
6. Cardinal-Health-VELA-...[03.Окт.2024]
7. Service Manual HAMILT...[02.Окт.2024]
8. Mindray DC-7 (ПО)[09.Сен.2024]
9. Руководство по эксплу...[26.Авг.2024]
10. Пароли для принтеров ...[20.Авг.2024]
1. tigran87[14.Авг.2025]
2. Roman1398[14.Авг.2025]
3. shumka01[14.Авг.2025]
4. саха[14.Авг.2025]
5. alex1971[13.Авг.2025]
6. dimcik[13.Авг.2025]
7. hiksus[13.Авг.2025]
8. seregond[13.Авг.2025]
9. Soldier[12.Авг.2025]
10. Foxsi[12.Авг.2025]
Этот сайт использует файлы cookies для более комфортной работы пользователя. Продолжая просмотр страниц сайта, вы соглашаетесь с Политикой использования файлов cookies.
