110 Thermal error 0903H перевод сообщения
70 degree C thermal safety
error
70° loop detected open
возможные причины
1. X–ray tube too hot;
normal error
2. Cooling problem
3. Wiring problem
4. Sensor problem (Tube)
5. rotation board
рекомендации по исправлению
–Wait for error clearance
–If persistent :
1/Check tube cooling (Fan), troubleshoot
115 volts from PDU to Fans,
through Rotation board; check tube
thermal sensor
2/ short circuit the sensor feedback
on rotation board connector and
verify that error disappears. If no,
replace rotation board
